Calling all PT Boat (all types) fans!
- EJM
This is for those interested in PT boats, coastal warfare craft, and other small craft.
ScottBono
Armament
Granted that the PT boats were manufactured by different companies was there standard armament for each boat - later customized to fit the mission? I've seen everything from quad .50's to the 20mm bow-mounted (as well as stern), etc. And as noted in another thread PT-109 had 37mm gun rigged on it. Next-door neighbor's inlaw served late '44 and told me every boat ended up different - in his limited experience.
First-class people seek out first-class people; second-class people always seek third-class folks...
JSJH
G'day Scott,
This is way too big a topic to answer in a thread. 'Suggest you first grab Squadron's PT Boats In Action book and visit T.Garth Conneley's PT-Boat-devoted site...then go outwards from there.
However, in a pre-1st grade personal summary of the subject, the further out (read away from a lot of brass staring down squadrons' necks), the more imaginative the boats' fit seemed to be. 'Have seen more variation in SW Pacific 80' Elcos than anywhere else, especially mid-war.
Hi All,
PT Boats have long been one of my favorites, my most recent builds in this type were conversions of Revell's PT 109 kit into late war boats. As it usually works out, as soon as you get something done the kit makers will bring out the same type just as Italeri has done with their 1/35th scale offering. While I really dig the subject the ol thing that makes me shy away is the large scale price tag. Of course, living in Las Vegas, if I ever hit a good jackpot, you know it will be on the top of my shopping list.
That is part way along in the process, as you can tell by all the white styrene, I made lots of changes.
After the intial base coats they look a little different from one another.
One is equipped with four roll off racks, 37mm cannon, 20mm Oerlikon and 5 inch rocket racks on the bow with scratched up 40 MM Bofors on the fantail.
The other has similar mountings with the aft set of roll off racks replaced with depth charge racks.
I am planning on adding to the PT line up with a few other 80 footers, one with 40 MM Bofors fore and aft as well as .50 caliber mounts sprouting from several positions to replicate the heavy gun boat type that was made up for the "barge busting" role. I am also hankering to kitbash one of the 80 footers into a faux 78 footer. That one promises to be a real trip with the differences in cabin arrangements and shapes.
- treadhead1952
TGConnelly
PT models
Sir -
Those are exceptional models. Please email me at PTConsultingNHR@aol.com and also at TCONNELL@stpaultravelers.com and please tell me more about them. Thank you.
Garth
Garth
- woody_b
Just follow the instructions in this thread: http://www.shipmodels.info/mwphpBB2/viewtopic.php?t=33
- treadhead1952
- Fritz
Hi All.
For anyone wondering how the WEM PE set works out for the Revell 1/72nd kit, I finished a build about 6 months ago. Garth has been kind enough to host some finished photos on his site. You can check out the results at: http://www.ptboatworld.com/PT109Model.htm
Enjoy
Fritz K.
Enjoy
Fritz K.
Best Regards
Fritz K.
Fritz K.
FIREMAN IV
- Devin
ducati650
Italeri 1/35th Elco PT Boat-WIP
I've been working on it since Feb. It will be the 495 boat from RON33 in Leyte in late '44.
To backdate the kit I've had to cast additional 20mm and mounts, modify the 37mm and make a mount, mod the roll-off racks, rework the 50 cal mount depression rails, scratch build the SO radar dome and mast, make the added twin 50 cal cradle and mount, add 2 50 cals and thier mounts and ammo boxes to one of the 20 mm, relocate the torpedo racks, make mounts for the 2 added 30 cals and cast additional ready-ammo boxes and 20 mm mags. I also had to fix the ammo belt feeders on the 2 50 cal turrets to make them correct for the barrels pointed up.
Still a lot to do but I thought I would share some photos.
- herrmill
- Guido
ducati650
Once I finish the build I plan on some washes and dry brushing just as you suggest.
I have some color photos of one of the RON33 boats from the mid to late '44 time period and they show a green and brown scheme. I sent the photos to John Snyder (Snyder and Short Enterprises) at WEM and he felt that it was probably Brown #4 and either Green #3 or 5-Navy Green. I used Brown #4 and Green #3.
Ed
Ed
- herrmill
Anyone Doing an RC Conversion?
Is anyone here besides me planning to RC this kit? My plan is to do a scale 3 motor conversion & would love to hear what others plan to do in terms of motor & running gear setup.
I saw the following on RC Universe today that pertains to keeping down the weight for this specific kit. It's shown as #7 under Steve Collins' post:
http://www.rcuniverse.com/forum/m_5454426/tm.htm
Thanks.
Chuck
Thanks.
Chuck
- PetrOs
- PetrOs Modellbau
Im waiting for a MS61 kit to appear, and did some research for that one. I would use some of the smaller slow-turning (no-load rpm of about 5000) Buehler motors, LiPo battery, some 10-15 gramm ESCs (or one high-current ESC driving all 3 motors, if doing 3 motors, you can put a cheaper and lighter 2gramm slowflyer forward-only ESC on a middle shaft), and a receiver for my Jamara RC, which is about 18 grams. 1 mini-servo driving all the rudders over a parallelogramm gear.
I suppose such a layout can work well also for a PT-boat.
Further kits in preparation.
- Bob Cicconi
Nice job! That's a lot of work, huh? I did one for Garth Connelly, but out of the box.
http://i45.photobucket.com/albums/f79/b ... CF1112.jpg
http://i45.photobucket.com/albums/f79/b ... CF1111.jpg
http://i45.photobucket.com/albums/f79/b ... CF1110.jpg
Bob Cicconi
