What If the Hood WASN'T sunk during the Bismarck engagement but only "mauled?" In my scenario she limps back to the UK and is made watertight/sea worthy once again but due to a more aggressive Germany in 1941/1942 the UK is unable to fully repair her (think the Pearl Harbor BBs stripped and patched at Pearl for their transit to the West Coast for major rebuilding) and they subcontract it out to the USA and or Canada with Hood emerging from the yards on or about 1943-44.
*Side note: I have the UK falling in 1944-45 time frame and the remnants re-locate to Canada and the US to continue fighting culminating with a very whiff heavy invasion of the UK in 1951!!!*
Ideas on how she would look gents? I'm working on a 3D model at the moment that I'll post a little later. Have to add the superstructure and weapons, rest is done. I've added a torpedo bulge similar to the US BB-43 class rebuilds already and a bulwark to the bow to aid in water displacement. She'll be re-armored with at least 5-6" decks and an increased side belt over the original 12" tapered to 5". How much I'm not sure, ideas?
Since the situation in the UK is a bad way I'm going to re-arm her with US weapons and electronics save for the main 15" battery. Do you think she could take twin 16" turrets like the US Colorado class? I MIGHT do that if its feasible, not sure of the details. Secondary battery will consist of the usual twin 5"/38s with twin and quad 40mms and twin 20mms. Modern US gun directors as well.
Superstructure wise I propose a forward setup as a mix of the HMS Belfast, USS Iowa, and HMS KGV. She'll get a UK style square open bridge atop the conning tower with a Mk-37 director abaft it as well as a main battery control tower abaft it. Two more Mk-37s will go on pedestals beside the after funnel with two searchlights. Two quad 40mms between the funnels and a trio between the funnels and after superstructure like in the Iowas. Funnels will be raised considerably and capped.
Aircraft won't be added in favor of a better AA battery.
Questions, did Canada posses the ability to manufacture any of the UK 40mm mounts? Sextuple, octuple, twins? If so I'll use though in lieu of quads and twins. We re-armed a UK DD with 5"/38s and Mk-37s at one point and the Brits LOVED them so I want to use them on this whiff.
Any thoughts, ideas, death threats, should I stop now and back away slowly?
Discuss!!!
