For those of you who have followed my work before, you have noticed that most of my projects have been cheap, low cost, or affordable solutions to modern Navy issues/problems. Mainly this has centered around NSFS. In this thread I will be branching out to address the Navy's desire to have a next generation cruiser. Both the Navy and the Congress have suggested/decreed that the new CG have the latest Aegis weapon system, SPY radar, and be nuclear powered.
I am going to step into this debate with a WIF concept for people to comment on. The situation is that the Navy has a very bad reputation for pursuing dead-on-arrival programs such as LCS and DDG-1000. The Navy has lost all credibility with the US Congress (the bill payers) that it can construct ships with reasonable capabilities at a reasonable price. Congress is likely correct in this assumption. The Navy has stated that it needs a replacement for the Ticonderoga-class CGs, and it would like for them to the BMD capable and nuclear powered. In order to convince Congress that the Navy can actually execute a class of ship without expending $10+ billion and 15 years in R&D, I hold the case that the solution is to look to the past.
Way back in the 1970s we had nuclear cruisers on order called the Virginia-class CGNs, and these were to be some bad @$$ ships. As they came on-line they actually turned out to be some extremely valuable ships. During the 1980s they were given the New Threat Upgrade (NTU) which brought them up to par with the Aegis weapon direction system. The only draw back was that NTU had rotating radars instead of static radars like Aegis. In all practicality and desipte other assertions, this did not make a lot of difference with the war-fighting capability of the NTU ships. However, because the Virginia-class CGNs had a lot of people on board, required a lot of money to maintain, did not have Aegis, were restricted to the majority AAW role with MK-26 launchers, had no helicopters, and were thus limited to escort duty, they were decommissioned, defueled, and the hulls are ready to be scrapped at 1/2 of their nuclear reactor�s lives.
Despite the four existing ships being ruined and destroyed, eleven ships of this class were initially ordered. Construction halted after the initial 4, because there was a concept to continue the class but equip it with the Aegis weapon system! This would have provided nuclear powered Aegis ships...�unlimited steaming Aegis platforms�. These ships would have been heavily armed and capable escort ships for nuclear powered aircraft carriers.
The ships would have been armed with the same weapon system as before: 2 Mk26 launchers, at least 8 Harpoons and 2 5�/54caliber guns. Because this debate continued into the 1980s when the Mk41 VLS was coming on board and the Mk26 was discontinued from production, there was a suggestion that the ships would have been armed with Mk41 VLS in addition to Aegis while being nuclear powered. If that modification had been constructed, the ship would have carried TLAM, SM-2, ASROC, and at least 8 Harpoons. With the addition of large amounts of TLAM via VLS they would have bordered on "capital ship" status.
Today: The Navy has recently decreed that it needs to buy 19 new cruisers, preferably nuclear powered, to replace the 27 Ticonderoga-class CGs. The realities of the US Navy are that the Navy is being forced to reduce its CVN force to unacceptably low levels for the foreseeable future.
I propose instead of sinking years and years and billions of dollars into reinventing the wheel, why not take the Aegis modification of the Virginia-class CGNs and update them with modern SPY-1D, Mk41 Mod15 VLS, and 16-32 harpoons in order to fill the role of the next class of cruiser. This would begin construction years ahead of other schedules, require less R&D costs, only require modification of vertical and 90 degree edges to reduce the ship's radar cross section, and if the Navy had the testicular fortitude provide the ships with a modern version of the Mk71 8" Major Caliber Light Weight Gun, the ship would indeed be a capital ship capable of not only performing missile strikes but major caliber gun strikes as well. With each 8� round carrying the equivalent of a Harpoon ASM impact and destruction, the 8� gun provides a very effective anti-ship and a land-attack capability. The best thing about the Mk71 is that it is 100% proven and ready for employment aboard USN ships. I would only suggest its electronics and gun shield be modernized. One might suggest the Advanced Gun System (ASG) instead of the Mk71. When one examines the capabilities and level of development one discovers that AGS is a terribly large gun system that provides inferior fire for ship roles, both in NSFS and NSuW. However, since the Mk71 8" gun is simply an expansion of the Mk45 5" gun, delivering 75% more ordnance than a 155mm (AGS round) and 250% of a 5inch round, incorporating the 8inch gun would only require a larger base ring than the Mk45 5", a slightly larger magazine, and it would deliver a far superior precision guided round onto either ship or shore targets. The large amount of surplus volume inside the hull, 600 8inch rounds forward and 475 8inch rounds aft, would provide this ship with an anti-ship and NSFS capability unheard of since the WWII designed heavy cruiser USS Newport News!
Because the Ticonderoga-class was literally an Aegis adaptation of the Spruance-class destroyer, and the Arleigh Burke-class DDG was "the great compromise ship", the expanded Virginia-class CGN with 128 VLS tubes, 2 8" guns, facilities for 2 HH-60 helicopters, SQQ-89(v)15 sonar, 8-32 Harpoon missiles, thicker armor protection, and nuclear power, actually steps into a true "cruiser"-like capability. The rest of the ship literally falls into place with little R&D costs. While it will still be expensive, approximately $2.5-3 billion, we would have an ultimately capable CGN for less than the price of the disappointing super stealth DDG-1000 destroyer whose run will be $6.1 billion for the first ship and supposedly 3.2 for follow on.
I plan to make a 1/700 test-run model of this class of ship before I make the financial investment into a 1/350 ISW Virginia-class model. Does anyone have suggestions or comments before I begin?
