PT Base Pictures?
Dockyard structures and equipment. Vehicles, Cranes, and buildings.
Sr. Gopher
PT Base Pictures?
Post by Sr. Gopher »
Well, as we all know, PT Boats served from the worst possible types of naval centers. Now, I've seen a number of pictures of the various bases, but I keep wondering, what larger ships (repair vessels, tenders, damaged combatants), would have to be forced to use these primitive facilities? I've been planning on acquiring the Corsair Armada ARD-4 class floating drydock, along with some vessels (PGMs, SCs, PCs...) to be accompanying my 6-8 PT boats, but still want something...more. The PT bases must have had some degree of shore facilities besides the quonset huts, but as to what, is what I ask. I need as many pictures as anyone here could show of PT Boat bases and the various vessels around them. This will be my own diorama without any historical background, so any pictures would be fine.
(Just for the record, #2 post in this section)
Current builds:
Planned builds:
3 more 1/700 AH submarines
Russ2146
Re: PT Base Pictures?
Post by Russ2146 »
As a start, here's a list of all PT Boat bases.
http://en.wikipedia.org/wiki/List_of_PT_boat_bases
Note that the left most objects in the following is a PT and a PT in floating drydock. Looks like SeaBee type.
It seems to me that a SeaBee creation would be a better way to drydock a PT that using an ARD
This is another way to drydock a PT.
USS California BB44
Post by USS California BB44 »
Had this pic bookmarked. PTs at Miami. Unknown date.
http://k53.pbase.com/o6/21/571721/1/788 ... e_400H.jpg
Reason: [img] tags appear to not work for that site - removed tags.
Current Builds:
1-350 DKM Z-39
1-350 USS Philippine Sea
Russ2146
Post by Russ2146 »
Here's some info on PT bases. Scroll down to page 73
http://www.ibiblio.org/hyperwar/USN/Clo ... /PT-2.html
floating drydock, a double-bubble gasoline barge, a crane barge, and a radar repair barge.jpg
Cliffy B
Post by Cliffy B »
Russ, what kind of auxiliary is that tender in the bottom photo? Looks like a small oiler and maybe an AOG. Do you have anymore photos of that tender?
Russ2146
Post by Russ2146 »
Its an LST reconfigured to an AGP by adding lots of gear to the main deck.
Specifically, that is AGP 11, USS Silenus. The converted LST's got named before other LSTs
http://www.navsource.org/archives/09/09/09idx.htm
Also see http://www.ptboats.org/20-04-05-tenders-005.html
Cliffy B
Post by Cliffy B »
So it is an LST, hmmm... looked too small at first. Found some nice high-res photos of one of the LST tenders in that link. Has shots of PTs nested alongside and closeups of them aboard being worked on.
http://www.navsource.org/archives/09/09/0910.htm
Thanks for the enlightenment :thumbs_up_1:
Hugh L
Post by Hugh L »
Here is an example of a PT Boat base. http://home.earthlink.net/~loosecannonp ... ecial.html
Sr. Gopher
Cliffy, if you like that LST conversion, what do you think of the C3 cargo conversions? I spent a fairly long time trying to find a kit of a C3 to attempt the conversion, but I never did. Heck, I've even considered tearing up a Bogue kit, but decided that scratchbuilding the bridge and deck would be way out of my league.
http://en.wikipedia.org/wiki/USS_Acontius_(AGP-12)
http://en.wikipedia.org/wiki/USS_Cyrene_(AGP-13)
Current builds:
Planned builds:
Hugh L
Post by Hugh L »
Both of those ships were C-1 and a lot smaller than a C-3.
Russ2146
Post by Russ2146 »
For a line drawing of the C-1 based AGP, go to http://drawings.usmaritimecommission.de/drawingmain.htm , pick a design and scroll down for drawings, including Navy variations. I could post the relevant drawing but I am unsure of how to handle the copyright.
Russ
Hugh L
Post by Hugh L »
DanCinSD
Post by DanCinSD »
Nice topic!
Looking for help on Quonset huts, is there a set of drawings that would be good enough to scratch build some.
Is there a place for information on them? Was there a "standard" size or design used in WWII? How about later?
Any good online sites for them??
Dan
What scale, Dan? If 1/700, Loose Cannon makes a diorama kit that contains a few quonset huts:
http://home.earthlink.net/~lcpwebmaster/Kit119.html
DanCinSD
Post by DanCinSD »
Timmy, Russ thank you, this will help.
I want to build one in 1/72 scale to team up with a modified Revell PT boat.
Dan
DanCinSD
Post by DanCinSD »
I just found this on the Italeri website.....
http://www.italeri.com/VisualizzaProdot ... PROD=01965
1/72 scale Quonset hut.
:thumbs_up_1:
Dan
tigercat
Post by tigercat »
Rob-UK
Post by Rob-UK »
The 1945 'John Wayne' movie 'They Were Expendable' is all about the PT boats in the Phillipines and is full of filmed shots of PT boats in their coastal bases as well as in action - maybe not filmed in the original setting (not sure) but cetrtainly a very inspiring journey into the world of the PT boats in action.
Return to “Dock and Harbor Equipment”
