What-If STOBAR Hermes/Viraat
metallicaman
since the hermes used to be a catobar carrier but was modified to be a stovl could it be possible to re add the angled deck to allow stobar operations to take place, and if so what kind of planes could operate off her decks
HvyCgn9
Re: stobar hermes/viraat
I think you will find the angle deck is still there mate! only the catapults and arrestor gear were removed back when she was 1st converted into a 'commando' carrier (pommy heli carrier with stacks of Royal Marines!) One of my mates is building her in 1/72 in Falklands homecoming condition...ie very rusty
Cheers Bruce
Cheers Bruce
building:
1/72 RC USS LONG BEACH CGN9
1/72 RC USS CALIFORNIA CGN36
1/72 RC USS SAIPAN LHA2
1/72 RC USS SHARK SSN591
1/72 RC USS SEAWOLF SSN21
1/72 RC USS ALBANY CG10
- doog_k
You'd need to reinstate the chunks cut from the angled del to accommodate the LCMs on Davis.
As for what could operate from the delckif you did? MAYBE Rafale M but the last fast jets she operated would have been Sea Vixens, Buccaneers and Scimitars, not really in the same league........
On the Slips:
1/144th Stand-off scale:
IJN Nisshin
HMAS Albatross
Keels laid: IJN Tone
Frames laid 1/25: DDR KleineSchnellBoot
http://www.edinburghmodelboatclub.org.uk
https://www.facebook.com/pages/Edinburg ... 2565540179
IJN Nisshin
HMAS Albatross
metallicaman
could the rafale take off from the rampdoog_k wrote:You'd need to reinstate the chunks cut from the angled del to accommodate the LCMs on Davis.
- Simon_Hwood
Mig 29s, Su27s?
http://www.youtube.com/watch?v=D3AMB7ZF ... re=related
http://www.youtube.com/watch?feature=pl ... SyDa_J0XaM
Si
Si
Reason: youtube video embedded.
Simon Heathwood
metallicaman
i think those would be a little bit to big for the viraat
indigodave
I don't see why Viraat couldn't operate Fulcrums Loaded weight: 15,300 kg (33,730 lb) after all she operated the Blackburn Buccaneer Loaded weight: 28,000 kg (62,000 lb)
She's probably just worn out and not worth the conversion
I've been told Orange Hobby are going to do her in Falklands fit and 1960's fit. Now that would be Fantastic
