I was wondering, what is the best way to touch up paint that has bled under the masking tape? Such as the black boot stripe bleeding onto the hull red or upper hull grey?
Seems like it could be a never ending process to get the lines perfect.
when you say spray with future, what is future.do you mean floor wax ,if so how does the paint stick to it?oh never mind a few threads down i found the answer.Devin wrote:Instead of using the last color to seal the masking tape, I spray a coat of Future. The advantages of Future over paint are that you don't have to worry if you're masking over multiple colors (such as hull camouflage), the Future goes on much thinner than paint, and is dry enough to paint over within a few minutes.
